VMProtect for .NET released
Lafko
Re: VMProtect for .NET released
Post by Lafko »
Admin wrote:Последнюю версию чего?
VMProtect Professional, мне на почту пришла 1131, а демо версия 1135 - она работает как надо
VMProtectDemo (build 1137):
Пример скрипта для переименования символов:
function RandomName()
	return string.format("%08X", math.random(0x100000000))
end
function RenameToken(token)
	if (token:type() == TokenType.TypeDef) then
		print("TypeDef:", token:fullName())
		if (token:value() == 1) then
			-- don't rename "<Module>"
			return
		end
		token:setNamespace("")
		token:setName(RandomName())
	elseif (token:type() == TokenType.MethodDef) then
		print("", "MethodDef:", token:name())
		if (bit32.btest(token:flags(), NET.mdRTSpecialName)) then
			-- don't rename ".ctor", ".cctor"
			return
		end
		if (bit32.btest(token:flags(), NET.mdVirtual)) then
			-- don't rename virtual methods
			return
		end
	elseif (token:type() == TokenType.Field) then
		print("", "Field:", token:name())
	elseif (token:type() == TokenType.Param) then
		print("", "", "Param:", token:name())
	end
end
function OnBeforeCompilation()
	math.randomseed(os.time())
	local classes = vmprotect.core():outputArchitecture():streams():table(TokenType.TypeDef)
	for i = 1, classes:count() do
		local type_def = classes:item(i)
		RenameToken(type_def)
		local methods = type_def:methods()
		if (methods) then
			for j = 1, methods:count() do
				local method_def = methods:item(j)
				RenameToken(method_def)
				local params = method_def:params()
				if (params) then
					for k = 1, params:count() do
						RenameToken(params:item(k))
					end
				end
			end
		end
		local fields = type_def:fields()
		if (fields) then
			for j = 1, fields:count() do
				RenameToken(fields:item(j))
			end
		end
	end
end
Lafko
Post by Lafko »
Спасибо, а приведите пожалуйста пример
-- don't rename "Namespaces"
В смысле?
if (token:namespace() == "xxxxxxx") then return end
3dsboy08
Post by 3dsboy08 »
Admin wrote:VMProtectDemo (build 1137):
Could I please be sent this new build? Would like to use the new renaming features.
Thanks.
Lafko
Post by Lafko »
Admin wrote:VMProtectDemo (build 1140):
В этой версии работает упаковка + пропали ошибки защиты некоторых функций, не могли бы вы отправить мне эту версию на email VMProtect Professional
maloyfoogel
Post by maloyfoogel »
Добрый день! Решил изучить возможности VMProtect под .NET. Скачал VMProtect Demo V3.4.0 build 1148. Модернизировал пример проекта на C# в папке license. Хотел организовать получение лицензии с помощью кода активации и демо версии сервера лицензирования http://weblm.vmpsoftware.com/. Но при отправке кода активации в приложении вылетает ошибка.
Подробный план действий:
1)Отредактировал пример проекта C:\Users\Public\Documents\VMProtect\Licensing\Net на отправку кода активации и получение лицензии
2)Добавил параметр "Сервер активации" - http://weblm.vmpsoftware.com/activations.php
3)Импортировал проект на сервер лицензирования (Product #3960)
4)Создал код активации (2019-09-22 Product #3960 sdfs [email protected] THMR-U3V2-93FD 1 / 0)
5)Скомпилировал проект через VMProtect Demo
6)Запустил, указал код активации, приложение закрывается.
Ошибка.zip
Текст ошибки
(1.66 KiB) Downloaded 881 times
Net.zip
Сам проект
(382.88 KiB) Downloaded 909 times
waterlord
Post by waterlord »
Можно ли получить на почту build 1155 ultimate версии или данные версии пока только для demo билдов и ждать релиза?
Nalik
Post by Nalik »
При покупке Professional Edition персональной лицензии за $249 будет ли в неё включена VMProtect for .NET?
http://vmpsoftware.com/purchase/buy-online/
