I've a 64-bit COM DLL written in Delphi XE3 and protected by VMProtect Ultimate 2.07.
The protected DLL registers OK under Win7 64, (using regsvr32.exe)
however,
it fails to register on Win8 (the same DLL file) , and no error messages show up.
I confirm that without protection, the 64-bit DLL registers OK on Win8,
Please advice! thank you!
64-bit COM DLL registration under Win8
- 11.png (84.95 KiB) Viewed 9524 times
Re: 64-bit COM DLL registration under Win8
Did you check your DLL with version 2.12?
Version 2.12
[!] PE: fixed some errors in x64 mode
[!] PE: fixed error in applications with IMAGE_DLLCHARACTERISTICS_NX_COMPAT flag
[+] PE: Windows 8 support added
[+] WebLM: Russian and Chinese localizations added
The price of upgrading is $69. Please use the following order link:
https://secure.payproglobal.com/orderpa ... ucts=37562
Thanks.. VMP 2.12 is great, it solves the registration problem under Win8.
is this $69 only valid for one year ? It says "Yearly Subscription"? Does it mean I get free updates within one year? The license for VMP itself is forever, right?
