Solved:Unlimited number of activations?
bitman2112
Post by bitman2112 »
Can someone tell me how to set unlimited number of activations for an Activation Code in WebLM?
The documentation says the following: But the screen shots are hard to read for the most part.
The activation code should be generated once, manually and stored in the application. You need to set unlimited number of activations for that code
Thanks.
:Ron
found the following thread with google, but searching for "unlimited" here produced nada.
I made a western grammatical change for yankee doodles.
Thanks for your report. The bug in WebLM is fixed.
P.S. For trial activation code you can use unlimited activation count (the value of "Activations Count" NEEDS TO BE be empty).
Re: Solved:Unlimited number of activations?
You are right. For unlimited number of activations the field "Activations Count" must be empty.
