VMProtect failing to decrypt a string the second time
ChMo
Post by ChMo »
This issue occurs with VMProtect Ultimate 2.13.5.
My reduced code looks like this:
	char* p1 = VMProtectDecryptString("IdenticalTest") + 3;
	DoStuff(p1, "Foo");
	VMProtectFreeString(p1 - 3);
	DoStuff(p1, "Bar");
The compiler optimizes it, by referencing the constant string using a register.
Here are some disasm snippets for it:
00F0DBA0  mov         esi,dword ptr [__imp__VMProtectDecryptStringA@4 (1517A84h)]
00F0DBC5  mov         edi,dword ptr [__imp__VMProtectFreeString@4 (1517A80h)]
00F0DBCD  mov         ebx,offset string "\xb2\xdf\xf6Service" (1578570h)  ; Here it goes
00F0DBD2  push        ebx
00F0DBD3  call        esi	; VMProtectDecryptStringA
... DoStuff()
00F0DC49  mov         eax,dword ptr [p1]
00F0DC4C  add         eax,0FFFFFFFDh
00F0DC4F  push        eax
00F0DC50  call        edi	; VMProtectFreeString
00F0DC52  push        ebx
00F0DC53  call        esi  	; VMProtectDecryptStringA
This works fine, as long as the executable isn't protected yet.
Once the executable is protected, the second DoStuff() call receives a pointer to garbage as first argument.
In the protected version the disasm looks like this:
ebx: Still some old value from before the function call. Doesn't point to anything interesting at this time.
00000000`22e11738 b0 08 b4 00 f1 08 b4 00 32 09 b4 00 73 09 b4 00 b4 09 b4 00 33 0a b4 00  ........2...s.......3...
00000000`22e11750 b5 0a b4 00 f1 0a b4 00 2d 0b b4 00 6d 0b b4 00 ad 0b b4 00 e0 0b b4 00  ........-...m...........
00000000`22e11768 12 0c b4 00 44 0c b4 00 76 0c b4 00 9e 0c b4 00 c6 0c b4 00 e1 0c b4 00  ....D...v...............
005edbcd e9f29ed400      jmp     01337ac4 ; Constant hiding I assume?
005edbcd  mov         ebx,offset string "\xb2\xdf\xf6Service" ; This *was* the original line, just inserted here as explanation
005edbd2 53              push    ebx
ebx: Now points to a different address, the properly decrypted string
00000000`063c55f8 b2 df f6 53 65 72 76 69 63 65 00 ab ab ab ab ab ab ab ab fe ee fe ee fe  ...Service..............
00000000`063c5610 00 00 00 00 00 00 00 00 c8 9a 30 76 32 cd 00 00 c0 68 3c 06 60 51 3c 06  ..........0v2....h<.`Q<.
00000000`063c5628 ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe  ........................
005edbd3 ffd6            call    esi ; Also DecryptString?!
005edc09 8b45fc          mov     eax,dword ptr [ebp-4] ss:002b:0018dba4=063c55fb
005edc0c 83c0fd          add     eax,0FFFFFFFDh
005edc0f 50              push    eax
005edc10 ffd7            call    edi	<-- FreeString
ebx: Still points to the same address, but the decrypted string is gone
00000000`063c55f8 c0 68 3c 06 60 51 3c 06 ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe  .h<.`Q<.................
00000000`063c5610 ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe ee fe  ........................
005edc12 53              push    ebx ; Broken EBX?
005edc13 ffd6            call    esi ; Also DecryptString?
After each ESI call EAX is identical to EBX.
This results in garbage being passed on as string to further DoStuff() calls
For some reason it doesn't occur in a minimal test-application.
But only in the full one. Maybe because different heuristics or optimizations are triggered.
Is this information sufficient for fixing the issue, or should I try harder to generate a minimal application for reproducing the issue?
Re: VMProtect failing to decrypt a string the second time
Could you send us a test application (original EXE+VMP+MAP file) that has this problem?
