VMProtect fails with "Stream read error"
stevo9876
Post by stevo9876 »
hi, I am trying to vmprotect a large binary of size 85MB. The map file is 210MB in size. after a few minutes, with the "packing" progress bar nearing 100%, VMProtect stops with the error "Stream read error".
I have tried adjusting options - type and number of protected functions, but nothing seems to make it work.
Is there a size limitation that I am hitting?
thanks,
steve
Re: VMProtect fails with "Stream read error"
Could you send us a test example (original EXE+MAP+VMP files) that shows your problem?
stevo9876
Post by stevo9876 »
Can you reply offline (of this forum), using my email address, on how to send an example in a non-public fashion?
thanks,
steve
Please send your example to [email protected]
