If I enable code virtualization check if will stop program running at Virtualbox which is good.
However, if I turned on the BIOS setting (enable virtualization support for Intel CPU), it also stop program running even I am just normally using my laptop (Thinkpad T520)
Code Virtualization check problem (bug)
- VMProtect reports error even the program is running normally. (NOT in virtual machine)
- cannot-run-vm.jpg (11.82 KiB) Viewed 13824 times
- Enable [Virtualization Support] in Bios for Intel CPU
- bios-virtualization.jpg (184.77 KiB) Viewed 13824 times
Re: Code Virtualization check problem (bug)
When this is set to [enabled], the VMProtect has a false-alarm, but this is not good.
Please could you check and fix, thanks.
What operation system do you use on this computer?
It is Win8.1 64-bit
8GB RAM
8GB RAM
You need to disable the role "Hyper-V" because it works as a virtual machine.
How (where) can I disable Hyper-V ?
In VMProtect, it only has two options regarding to Virtual machine (Yes / No).
I am also developing some applications for windows phone using Visual studio, it requires me to turn this setting (in bios) on otherwise the emulator will not work.
After I turn off BIOS virtualization, it is ok no matter Hyber V is on or off.
If I turn on BIOS virtialization, it doesn't work any way (even I turn off Hyber V)
You are right.
my mistakes, yes, turning Hyper V off solves the problem. good to know this. thanks.
