No functions for protection with kernel- mode driver
camxxcore
Post by camxxcore »
I recently purchased the professional version of VMProtect. But I'm having a problem where there are no functions for protection showing when attempting to protect a kernel- mode driver, even with a map file generated. I can still apply protection by manually specifying the entry point of those functions, but this is obviously not the solution I am looking for. Would appreciate any help.
No functions available:
Visual Studio 2019:
Driver Configuration:
camxxcore
Re: No functions for protection with kernel- mode driver
Post by camxxcore »
Solved by using a PDB file instead. I guess I had to delete the .map file for VMP to notice that PDB file.
Could you send us an example of a MAP file?
