vmprotect failing but displaying a success message anyway
balackin
Post by balackin »
Hey,
I have protected my app with vmprotect and it shows success.
The output file size is 430% of the unprotected exe and when i do a memory dump of it I can see all the vmprotect macro strings and none of the code is mutated/virtualized, its all plain and visible.
I also tried the demo 3.0 version and it seems to work, the file size is only slightly larger than the normal file and everything is protected the way it should be but I get the "this was protected by an unlicensed vmprotect" message (even though i placed the key file in the same folder).
Help would be appreciated!
Thanks.
Re: vmprotect failing but displaying a success message anywa
Could you send us a test example that shows your problem?
