How to use VMProtect properly in .NET?
khangminh
Post by khangminh »
Hello Sir,
Do i need to use VMProtect.SDK.DecryptString for every string I need to use in my program? If the strings are not visible to the user or just passed from varibles? Is it really helps me to secure the strings?
Thanks
p/s: Would you give me another details example how to use it properly? The Examples includes for .Net are not enough.
Re: How to use VMProtect properly in .NET?
You have to use VMProtect.SDK.DecryptString for all strings that you want to hide from decompiler in your assembly. Something like this:
MessageBox.Show(VMProtect.SDK.DecryptString("Correct password"), VMProtect.SDK.DecryptString("Password check"), MessageBoxButtons.OK, MessageBoxIcon.Information);
