Floating point instruction virtualization error
tmp
Post by tmp »
Hi,
I was testing latest version of VMProtect (3.0.2.470) and it seems that it cannot virtualize fldcw instruction. What's interesting its counterpart fstcw compiles without problems.
Here's a minimal sample to reproduce this issue (compile using VS):
__declspec(noinline) void vmProtectionFailureTest()
	unsigned short cw;
	__asm
		fstcw cw
		fldcw cw
int main()
	vmProtectionFailureTest();
	return 0;
Protection settings and compilation log:
Re: Floating point instruction virtualization error
Thank you for your report. We'll fix it in next build.
Wow... so much to learn!
tmp wrote:Hi,
	unsigned short cw;
	__asm
		fstcw cw
		fldcw cw
int main()
	return 0;
tmp
Post by tmp »
Thanks for fixing this issue in 3.0.3.481. Unfortunately I've found another corner case for virtualization:
Again it's suprising that complementary pushad is handled properly but popad is not.
