Version 3.0.3 crashing the software
primarypower
Post by primarypower »
Hi
After updating from 3.0.2 to 3.0.3 my software is now crashing...
I´m not sure where it is crashing because I cannot debug it, but something that was changed is now crashing it and I had to revert to 3.0.2.
Here are some details:
- Built with Delphi XE7
- Windows 32bit Service Application
- I´m using ONLY Virtualization and Mutation, no other protection mechanism is used on the project
- Memory Protection: No
- Import Protection: No
- Resource Protection: No
- Pack the output file: No
- Debugger Detection: No
- Virtualization Tools: No
- VM Segments: .dgf
- Use Taggant System: Yes
- Strip Debug information: Yes
- Strip Relocations: Yes
- Watermark: no watermarks used
So, basically I´m just protecting a few licensing routines of my application using ULTRA (Mutation + Virtualization)
Maybe it is related to your new Exception handling improvements, but it could also be related to the new virtualized instructions as per release notes...
Re: Version 3.0.3 crashing the software
Could you send us a test example (original EXE+MAP+VMP files) that shows your problem?
