Command Line VMProtect problem
camxxcore
Post by camxxcore »
I have configured my project to run VMProtect at the post- compilation stage. For some reason an issue has arisen where it takes forever to complete in the final stage "saving startup code" even though using the GUI interface completes the compilation almost immediately. Is there something I should look for to avoid this problem? This problem came after making some tweaks to the .vmp file so I suspect I added a function that is not analyzed properly or some other feature. Please offer any insight, thank you.
camxxcore
Re: Command Line VMProtect problem
Post by camxxcore »
I sent the problematic files in a private message.
You forgot to send MAP/PDB file.
