Anti debugger problem
nillman
Post by nillman »
Hello
I have the latest version of the software(3.4) with a license and I use it. But there's a big bug in the software's anti-debugger section that can be easily bypassed.
Explanation:
1- Using x32dgb ,x64dbg or ollydbg software
2- Installing and activating the sharpOD v0.6 plugin
3- Easy packed application debugging
See the uploaded image. And test yourself.
Please fix the bug.
Best regards
SharpOD file https://mega.nz/file/ruZQ0QqB#30YxxK1cB ... G-HJtxxpzo
Re: Anti debugger problem
Thank you for your report. We'll fix it soon.
ovid
Post by ovid »
they will fix again anti anti debug
you should protect your app damn hard,
if you want live longer.
and not end in lavteam as public crack.
developer will fix 100x time again, but some smart ass Chinese will break again.
so don;t trust anti debug feature, good for beginners.
Starting 3.5.1 there is no more working antidebug tools for x64dbg and other debuggers.
