Trying to protect an example exe and I'm having many issues.
Enabling "Memory Protection" results in a "File corrupted! This program... won't work anymore" error.
Enabling "Pack the Output File" results in a "The application was unable to start correctly (0xc000003e). Click OK to close the application" error.
Disabling "String relocations (for EXE files only)" results in the application never launching.
Is this a limitation of the demo?
VMP Demo Errors
Re: VMP Demo Errors
Could you send us a test example (original binary + VMP files) that shows these problems?
Re: VMP Demo Errors
Yes, but I do not want to post it publicly. Where can I send it?
Re: VMP Demo Errors
Please send to [email protected]
Re: VMP Demo Errors
Please try the 1185 build:
