Code Markers
RunninThruLife
Code Markers
Post by RunninThruLife »
When placing code markers in the source, is there a need for a marker to be placed above every single method, or just the method at the top of the section to protect? For example...
[VMProtect.Ultra]
public void TestMe(string testingParam)
    System.Windows.Messagebox.Show(testingParam);
[VMProtect.Ultra] //<--Is this necessary or can it be left out
public void TestMe2(string testingParam2)
    System.Windows.Messagebox.Show(testingParam2);
Also, the reference to VMProtect doesn't seem to have a definition for VMProtectEnd. How is this marker placed?
Thank you.
Re: Code Markers
You have to use [VMProtect.BeginUltra] for every method that you want to protect. Anyway, you can add/remove any method into a VMP project with the VMProtect's GUI.
RunninThruLife
Re: Code Markers
Thank you for responding.
Would you mind answering the other part to the question? What happened to the VMProtectEnd marker? Is it still used? I couldn't find it in the SDK.
Thank you.
Thank you for your time.
Re: Code Markers
Where do you see VMProtectEnd in VMProtect.SDK?
