Import Protection .NET
Sayni
Post by Sayni »
Hello, i have installed on my project costura for embedding my dll in my program (Bunifu Framework and VMProtect.SDK), when the program is running
it works great, I no longer need to put the dlls aside but if i protect my program with this options "Import Protection", vmp give my program obfuscated but it dont work, I have to put my theme dll next to the exe so that it works, otherwise it does not launch, on the other hand for the vmprotect.sdk dll this does not pose any problem
(Sorry for translate its google translator)
Re: Import Protection .NET
What build of VMProtect do you use?
