Avira: TR/Crypt.XPACK.Gen3
PfundsteinE
Post by PfundsteinE »
Hallo, we have upgraded VMProtect Prof. 3.1.2 to VMProtect Prof. 3.5
Unfortunately we can not use the version 3.5 in our build process.
The application exe file created by VmProtect_Con.exe will not be accepted by AVIRA. Avira detects TR/Crypt.XPACK.Gen3.
The reason is the usage of VMProtectDecryptStingW with 'smtp.ionos.de'.
We are using Delphi Tokyo 10.2.3:
Result := VMProtectDecryptStringW('smtp.ionos.de'); //Avira: Trojaner TR/Crypt.XPACK.Gen3
Furthermore I tested with 'smtp#ionos#de'. Avira now detects Trojaner TR/Crypt.XPACK.Gen2.
Result := VMProtectDecryptStringW('smtp#ionos#de'); //Avira: Trojaner TR/Crypt.XPACK.Gen2
Hopfully you can help me
Greetings Edmund
PS: the optons file is attached.
lignocam.exe.vmp.zip
(344 Bytes) Downloaded 238 times
Re: Avira: TR/Crypt.XPACK.Gen3
It's called "false positives" that shows low quality of antivirus. We can recommend to use a code signing certificate for decrease "false positives".
