VMProtecting my DLL causes it to crash.
mmff
Post by mmff »
Not sure if my other post went through but I made a small mistake, VMProtect is definitely not conflicting with a library I'm using because another DLL I have VMProtected with the same library works perfectly fine. No clue what is going on here, please reply for more information.
(Crash occurs a few seconds after injecting into the process—this doesn't happen with the non-VMProtected DLL.)
Re: VMProtecting my DLL causes it to crash.
Are you a registered user of VMProtect?
mmff
Post by mmff »
Admin wrote:Are you a registered user of VMProtect?
Yes, commenting out some code fixes the crashing when I inject the VMProtected DLL (the code that was commented out is functional it works in the non-VMProtected DLL).
Please provide us more detailed information about your license because we didn't find your email in our customer database.
