Maximum exe limit
salaxo
Maximum exe limit
Post by salaxo »
Hi all,
How can I limit the maximum running process?
I would now turn to an enigma protector.
That's the name of the feature there, but I can't find it here. "Executed Copies"
Re: Maximum exe limit
Unfortunately VMProtect has no such feature.
salaxo
Post by salaxo »
Admin wrote:Unfortunately VMProtect has no such feature.
Thanks for the information.
Can't check the filename function?
Example:
Protector make xy.dll, and if filename changed, program cant run.
Can this be solved, even with a script?
You can check it by your self at the startup of your DLL.
Catharsis
Post by Catharsis »
salaxo wrote:Hi all,
You can implement this yourself by using named mutexes.
