Bugs?.Net Program with vmprotect 3.5.0.1229 protect cause a uncatch error code 0xc0000409 in clr.dll
wxscript
Post by wxscript »
hello Admin
my .Net application protected by vmprotect 3.5.0.1229 . but cause a error that .net framework count not catch any error by ExceptionHandle.
//设置应用程序处理异常方式:ThreadException处理
Application.SetUnhandledExceptionMode(UnhandledExceptionMode.CatchException);
//处理UI线程异常
Application.ThreadException += new System.Threading.ThreadExceptionEventHandler(Application_ThreadException);
//处理非UI线程异常
AppDomain.CurrentDomain.UnhandledException += new UnhandledExceptionEventHandler(CurrentDomain_UnhandledException);
the windows event log records seems that , clr crash code is 0xc0000409
i find a topic similar as my problem , links as : http://vmpsoftware.com/forum/viewtopic.php?t=17844 , https://bbs.csdn.net/topics/392084751?t=123&list=lz
i can comfirm that without protection , my .Net application run in debug build can nou cause this error.
this error seems casue a stack overflow bugs.
please help me..
错误应用程序名称: TestVersion.exe,版本: 1.0.0.0,时间戳: 0x60408d34
错误模块名称: clr.dll,版本: 4.8.4341.0,时间戳: 0x6023024f
异常代码: 0xc0000409
错误偏移量: 0x0060cd78
错误进程 ID: 0x4c48
错误应用程序启动时间: 0x01d710c925eb5042
错误应用程序路径:TestVersion.exe
错误模块路径: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
报告 ID: 195a2d8b-7074-4d5d-8e83-0d79494204bf
错误程序包全名:
错误程序包相对应用程序 ID:
Re: Bugs?.Net Program with vmprotect 3.5.0.1229 protect cause a uncatch error code 0xc0000409 in clr.dll
Please try the latest build.
wxscript
.Net Program with vmprotect 3.5.0.1265 protect also cause a uncatch error code 0xc0000409 in clr.dll
Post by wxscript »
Admin wrote:Please try the latest build.
Hello Admin,
I was receive the latest build 3.5.0.1265 , but the problem still exist.
because of my .net app is a large program , i can not get the exact Fault location .
could you give me some reason which could cause clr crash as error code 0xc0000409?
or how to trace stack in protected mode.
wxscript
Post by wxscript »
Oh,i build example and send it to [email protected] <[email protected]>; >_< forum attachments cause error that i count not upload it
run it ,wait half an hour, crash
We have checked your example and it works fine.
wxscript
Post by wxscript »
my example is not an immediate crash. could you give me you clr.dll version? my clr.dll version is 4.8.4341.0
i can not confirm the problem is a .net rumtime bug , or is vmprotect bug.
i test my .net app on 3 computers , both windows 10 , the error same . clr.dll version is 4.8.4300.0 \ 4.8.4341.0
parita85
Post by parita85 »
Dear Admin,
I have the same problem which is on going via this thread. here is the detail.
I have VMProtect Professional version 3.5.0. I have protected my two dotnet desktop application. one is developed using WPF and another I have developed using Window C#. In both of this application if system is either idle for a long duration e.g 10 mins sometime or sometime 2 mins also And in another WPF system if my printing is going on then in between of that , I am getting below error in event log of window 10/ 7 operating system.
Error Detail:-
Faulting application name: MYEXE.exe, version: 1.12.0.0, time stamp: 0x8597da96
Faulting module name: clr.dll, version: 4.0.30319.34209, time stamp: 0x5348961e
Exception code: 0xc0000409
Fault offset: 0x002ec083
Faulting process id: 0xff0
Faulting application start time: 0x01d77a3050d6d39d
Faulting application path:
Faulting module path: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
Report Id: e2c2b22d-e62c-11eb-8853-1c1b0d312693
Issue is there so might be I can not share my full project and even it's uncertain problem not sure always come but suddenly system stop working and from my both the project , I am getting the above log.
Without protection , it's working perfectly.
Only Memory protection is On , rest all the options are off.
Thanks,
Parita
