Marker issues
roxaz
Marker issues
Post by roxaz »
I test VMProtect on x64 dll, so i have to use marker call. Thing is that VMProtect reports that there are 4 unpaired markers, and it does not display any marked functions in the list of functions to virtualize. So not a single marked function is virtualized. Is demo version supposed not to handle marked functions or whats wrong? By the way i checked my dll in disassembler - i have matching count of calls to virtualization start and end callbacks.
The cause of this situation - the code optimization. In the result you have some VMProtectEnd on one VMProtectBegin.
ssack
Post by ssack »
Admin wrote:The cause of this situation - the code optimization. In the result you have some VMProtectEnd on one VMProtectBegin.
how to solve?
Use MACRO markers instead API markers.
ssack
Post by ssack »
new makers no macro define
You can use markers from previous version:
	#define VMProtectBegin \
		__asm _emit 0xEB \
		__asm _emit 0x10 \
		__asm _emit 0x56 \
		__asm _emit 0x4D \
		__asm _emit 0x50 \
		__asm _emit 0x72 \
		__asm _emit 0x6F \
		__asm _emit 0x74 \
		__asm _emit 0x65 \
		__asm _emit 0x63 \
		__asm _emit 0x74 \
		__asm _emit 0x20 \
		__asm _emit 0x62 \
		__asm _emit 0x65 \
		__asm _emit 0x67 \
		__asm _emit 0x69 \
		__asm _emit 0x6E \
		__asm _emit 0x00 \
	#define VMProtectBeginVirtualization \
		__asm _emit 0xEB \
		__asm _emit 0x10 \
		__asm _emit 0x56 \
		__asm _emit 0x4D \
		__asm _emit 0x50 \
		__asm _emit 0x72 \
		__asm _emit 0x6F \
		__asm _emit 0x74 \
		__asm _emit 0x65 \
		__asm _emit 0x63 \
		__asm _emit 0x74 \
		__asm _emit 0x20 \
		__asm _emit 0x62 \
		__asm _emit 0x65 \
		__asm _emit 0x67 \
		__asm _emit 0x69 \
		__asm _emit 0x6E \
		__asm _emit 0x01 \
	#define VMProtectBeginMutation \
		__asm _emit 0xEB \
		__asm _emit 0x10 \
		__asm _emit 0x56 \
		__asm _emit 0x4D \
		__asm _emit 0x50 \
		__asm _emit 0x72 \
		__asm _emit 0x6F \
		__asm _emit 0x74 \
		__asm _emit 0x65 \
		__asm _emit 0x63 \
		__asm _emit 0x74 \
		__asm _emit 0x20 \
		__asm _emit 0x62 \
		__asm _emit 0x65 \
		__asm _emit 0x67 \
		__asm _emit 0x69 \
		__asm _emit 0x6E \
		__asm _emit 0x02 \
	#define VMProtectBeginUltra \
		__asm _emit 0xEB \
		__asm _emit 0x10 \
		__asm _emit 0x56 \
		__asm _emit 0x4D \
		__asm _emit 0x50 \
		__asm _emit 0x72 \
		__asm _emit 0x6F \
		__asm _emit 0x74 \
		__asm _emit 0x65 \
		__asm _emit 0x63 \
		__asm _emit 0x74 \
		__asm _emit 0x20 \
		__asm _emit 0x62 \
		__asm _emit 0x65 \
		__asm _emit 0x67 \
		__asm _emit 0x69 \
		__asm _emit 0x6E \
		__asm _emit 0x03 \
	#define VMProtectEnd \
		__asm _emit 0xEB \
		__asm _emit 0x0E \
		__asm _emit 0x56 \
		__asm _emit 0x4D \
		__asm _emit 0x50 \
		__asm _emit 0x72 \
		__asm _emit 0x6F \
		__asm _emit 0x74 \
		__asm _emit 0x65 \
		__asm _emit 0x63 \
		__asm _emit 0x74 \
		__asm _emit 0x20 \
		__asm _emit 0x65 \
		__asm _emit 0x6E \
		__asm _emit 0x64 \
		__asm _emit 0x00 \
gnjp
Re: Marker issues
Post by gnjp »
I had this problem too, turning optimization of using pragma fixed it:
in MSVC++
#pragma optimize( "g", off )
// code
#pragma optimize( "g", on )
sjsteve33171
Re: Marker issues
Post by sjsteve33171 »
Thanks to both of you it fixed my error of unmatched pairs.
One other way is to edit the properties of the project, expand C++, select Optimization and disable it from the top option. After that select Code Generation and disable the Buffer Security Check.
Everything works after that.
