C++ named pipe not working after protection
smurfin4tor
Post by smurfin4tor »
Hey,
I have two solutions, one C# .NET, one C++.
The C# solution created a named pipe to which the c++ solution connects after executing.
Protecting the C# solution is fine but once I protect the c++ solution as well the named pipe won't work anymore.
This is how i create the named pipe in the C++ solution:
 HANDLE hPipe;
    do
        hPipe = CreateFile(PIPE_NAME, GENERIC_READ, 0, nullptr, OPEN_EXISTING, 0, nullptr);
        std::cout << "INVALID_HANDLE_VALUE" << std::endl;
        std::this_thread::sleep_for(std::chrono::milliseconds(1));
    } while (hPipe == INVALID_HANDLE_VALUE);
    if (hPipe == INVALID_HANDLE_VALUE)
        std::cout << "INVALID_HANDLE_VALUE" << GetLastError() << std::endl;
        return -1;
    DWORD mode = PIPE_READMODE_MESSAGE;
    SetNamedPipeHandleState(hPipe, &mode, nullptr, nullptr);
    bool success = false;
    DWORD read;
    while (!success)
        TCHAR chBuff[BUFF_SIZE];
        do
            success = ReadFile(hPipe, chBuff, BUFF_SIZE * sizeof(TCHAR), &read, nullptr);
        } while (!success);
        SimulatePipeResult(chBuff);
Re: C++ named pipe not working after protection
We need a very simple example (original binary + vmp files) that shows your problem.
