Are nested functions obfuscated?
db2021
Post by db2021 »
We have a large project. Can nested functions be obfuscated all at once in it?
Re: Are nested functions obfuscated?
Do you mean nested functions in .NET application?
huyi51462
Post by huyi51462 »
Admin wrote:Do you mean nested functions in .NET application?
I don't quite understand this problem either.
If there are three functions like these:
void Fun_3()
int a= 3+3;
Fun_2();
void Fun_2()
int a= 2+2;
Fun_2();
void Fun_1()
int a= 1+1;
Fun_2();
int Main()
VMProtectBeginVirtualization("main")
int i = 3+2+1;
Fun_1();
VMProtectEnd();
return 0;
Fun_1,Fun_2,Fun_3,these three functions are not using markers or MAP-file.
The problem is:
After compilation in VMProtect,the code between VMProtectBeginVirtualization("main") and VMProtectEnd()in the Main like "int i = 3+2+1;" will be virtualized,but what about call to "Fun_1();" in the Main?
When the Main calls the Fun_1 , will the internal code of the FUN_1 such as "int a = 1+1;" be virtualized?
More like "int a= 2+2;" "int a= 3+3;" in the Fun_2 and Fun_3?
The problem is:
VMProtect will virtualize ONLY the marker "main". If you want to virtualize Fun_1 - you have to add this function into the "Functions for protection" section.
huyi51462
Post by huyi51462 »
The problem is:
Thanks, figured it out
