c# my app get's error after protecting
testtestg
Post by testtestg »
after I protect my application exe using vmp 3.5.0 I get this error in console after opening the exe: Operation is not valid due to the current state of the object.
my code is this github tool: https://github.com/Outbuilt/Auth.GG-CSharp
Re: c# my app get's error after protecting
Please send us original EXE+VMP files.
testtestg
Post by testtestg »
Admin wrote:Please send us original EXE+VMP files.
I Attached the 2 files
Files.rar
Here are both files
(356.16 KiB) Downloaded 233 times
testtestg
Post by testtestg »
Actually I found out this error mean's I get an HttpStatusCode.NotFound after requesting from a api, without the protection it work's well, it seems like vmprotect is blocking outgoing connections or something, help?
Your example requires Colorful.Console, DiscordRP, Leaf.xNet Also you forgot about FDP.exe.vmp (VMProtect project file for your example)
testtestg
Post by testtestg »
I actually have the exe and the dll's in the same folder, I don't think It's about it, and here is the .vmp
FDP.rar
(2.8 KiB) Downloaded 203 times
It seems you don’t understand that your example doesn’t work without all required dependences (Colorful.Console.dll, DiscordRP.dll, Leaf.xNet.dll, etc.), so your example is useless for us.
testtestg
Post by testtestg »
here's all the files, dll's and everything together does that help?
Release.rar
(737.86 KiB) Downloaded 241 times
Thank you for your example. We'll check it soon.
