Qt 5.15.0 MSVC 32Bit - Merging Problem!
MuratHSHN
Post by MuratHSHN »
https://prnt.sc/1qdft0p
As you can see in the picture, I embed Qt's libraries in the program, but I get this error: https://prnt.sc/1qdfuvg
Can you please help?
Re: Qt 5.15.0 MSVC 32Bit - Merging Problem!
Unfortunately "prnt.sc" is blocked in our country. Could you attach your screenshots to this topic?
MuratHSHN
Post by MuratHSHN »
MuratHSHN
Post by MuratHSHN »
Help please :/
MuratHSHN
Post by MuratHSHN »
Could you send us a test project (original EXE + VMP + all required files) that shows your problem?
MuratHSHN
Post by MuratHSHN »
Check your PM.
Fixed in the 1343 build.
MuratHSHN
Post by MuratHSHN »
Thanks!
