Can you enhance more features in ease of use?
paituo
Post by paituo »
Your software is very good and we will continue to use it. Can you enhance more features in ease of use?
1. Because the user-defined data provided by the license is limited,
can you provide an API for the VMProtectDecryptDataByKey function.
2. Can "key expiration date" support storing usage time and
prevent users from verifying only by modifying PC time.
Even though it may be easy to crack, it is certainly more troublesome than
directly modifying the local time.
YouBestClient
Re: Can you enhance more features in ease of use?
Post by YouBestClient »
I've waiting for such a functionality for a very long time. :?
What is a problem to make own VMProtectDecryptDataByKey and protect it with "Lock To Serial Number" feature?
Guys, VMProtect doesn't store anything on the user computer, because it's useless (just ask google what is "trial reset" programs)! If you want to prevent of changing the current date you have to use online activation (VMProtectActivateLisense + VMProtectSetSerialNumber) that receives the real date from an activation server.
P.S. We are not going to make "trash" APIs in our product because 99.99% of them can be implemented by common programmer in 10 minutes.
