newtonsoft json error
sisarpsarp
Post by sisarpsarp »
Hello there
process newtonsoft.json fails after encrypting the program. I don't do any other settings.
my settings
https://ibb.co/VtDLy9w
the code i use
https://ibb.co/PGb3fxP
Re: newtonsoft json error
What version of VMProtect do you use?
Could you send us a very simple test application (original EXE+ VMP files) that shows your problem?
sisarpsarp
Admin wrote:What version of VMProtect do you use?
I have solved my problem but I am having another problem.
I use VMProtect Personal License Lite
The error I got, I am using google api
WAR: Playing an assembly linking game.
For assembly encoding logging, set the [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) registry log to 1.
Note: There are some classifications of offenses associated with the integrated criminal record.
Logging registry days [HKLM\Software\Microsoft\Fusion!EnableLog] to delete this feature.
https://ibb.co/zFL5PZB
https://ibb.co/2Sr5d3k
sisarpsarp
can you help me? I'm waiting for support to publish the program
We are waiting for your example.
