Memory protection and load time
chmichael
Post by chmichael »
Seems support e-mail isn't working so i post here.
Just got VMProtect and use it on 1 of my apps.
When i use memory protection it take 15-20 seconds to load.
If i disable Memory Protection it loads quick!
Any ideas ? (Delphi)
Thank you
Re: Memory protection and load time
Do you use something like Detours for patching of VCL's code?
chmichael
Post by chmichael »
Hello
No, i'm using CEF (https://github.com/salvadordf/CEF4Delphi) library though that might do ?
Thank you
Do you know that your application patches own code (calls VirtualProtect + modifies memory + calls VirtualProtect with old protection)? VMProtect disallows to change the protection of read only memory and your code probably throws "Access Violation" exception that takes additional time at initialization.
chmichael
Post by chmichael »
Nope. unless a library does it! I take a look!
Thanks
