This is the result of my encryption with the linux version
Locked
lovees
Post by lovees »
This is the result of my encryption with the linux version, it seems that it cannot be encrypted, the program has been sent to you, with a video of the problem,
I am encrypting it with a linux program. Before the encryption, it was in linux: dotnet Shipsay.dll, and it was running normally, but it could not be encrypted. Please come closer. I have already encrypted it with a windows program in the windows version, and it runs normally. The linux version Yes, it cannot be encrypted under the linux program
VIDEO has been sent to the mailbox, the following is the picture, the direction of the arrow shows the error
Re: This is the result of my encryption with the linux version
It seems you use the option "Strip debug information". For .NET files this option renames classes/method/properties/fields in protected application and requires all .NET dependences. So you have to copy all .NET dependences (System.Runtime.dll, System.Private.CoreLib.dll, etc.) to the Linux folder with your application.
On Windows these files are usually located in the following folder:
C:\Program Files\dotnet\shared\Microsoft.NETCore.App\X.X.X.X
Where "X.X.X.X" is the .NET Core version.
lovees
Post by lovees »
The required files have been packaged normally and are in the directory
I don't know where did you get these files (System.Runtime.dll and System.Private.CoreLib.dll). Try to open them with VMProtect :wink:
lovees
Post by lovees »
These are the project generation, in the folder after the project is generated, the project has been sent to you by e-mail, System.Runtime.dll,System.Private.CoreLib.dll,System.Runtime.dll cannot be loaded and opened with VMProtect, please see the picture, and upload System.Private. CoreLib.dll , System.Runtime.dllinto the attachment
System.Runtime.dll.zip
(17.26 KiB) Downloaded 544 times
System.Private.CoreLib.dll.zip
(4.24 MiB) Downloaded 544 times
Unknown CPU type (0xFD1D) is the reason why VMProtect can't resolve these assemblies.
lovees
Post by lovees »
I will try to regenerate an X64 version, please wait a moment, but I feel that this is a bug in the LINUX version, because the test with the VMProtect_DEMO version is the same with other computers
lovees
Post by lovees »
It seems that all project generation net6.0\linux-x64 generation does not support at all even if the CPU is specified as X64, it should be the problem that VMProtect For Linux version does not support NET6, please update to solve this problem
Just copy .NET Core runtime from Windows machine.
lovees
Post by lovees »
In the beginning, I copy it from WIN and encrypted it. It has always been impossible to solve this file, but I have sent the project file to your E-MAIL for you.
Read my previous post more curefully:
VMProtect for Windows uses this directory for resolving .NET assemblies.
lovees
Post by lovees »
(4.32 MiB) Downloaded 804 times
This is the System.Private.CoreLib.dll (attached) copied from WIN, the error message: has an unsupported subsystem
OMG. The topic is closed.
Locked
