2 problem about the cli dll
Dnn
Post by Dnn »
[1]the uIntptr constructor could not be found after compilation
[2] only compile il part , the native part need load VMProtectSDK64.dll
problem.zip
(586.43 KiB) Downloaded 187 times
Re: 2 problem about the cli dll
1. Fixed in the 1451 build
2. VMProtect doesn't process native code/native imports from VMProtectSDK64.dll for mixed .NET applications.
Dnn
Post by Dnn »
Admin wrote:1. Fixed in the 1451 build
After testing, problem 1 is not completely fixed
In the demo, openprocess to the Calculator.exe
u can run a calculator.exe process before testing
		[VMProtect::BeginUltra]
		UIntPtr^ Testor::OpenProcessCLI(DWORD pid)//Calculator pid
			return  gcnew UIntPtr(Native::VMPOpenProcess(pid));//complete after:VMPOpenProcess result has value but uintptr ctor func not set value
simple demo code maybe you need
CLITest.zip
(2.77 MiB) Downloaded 174 times
