UserData how to set
vmpvmp
UserData how to set
Post by vmpvmp »
Support,
There is no example in documentation (expect this one with 'test mode' and ini file which does not work )
How to set custom UserData in runtime (Delphi) ?
rob
Re: UserData how to set
Do you mean the KeyGen usage or something else?
vmpvmp
Post by vmpvmp »
Admin wrote:Do you mean the KeyGen usage or something else?
Yes, Weblm keygen usage, I see there is field named "User data"
Is this possible to pass it to server together with activation code
I want to store there OS Version get and convert into user data.
Then using VMProtectActivateLicense pass it to server keygen
Unfortunately it's impossible. VMProtectActivateLicense doesn't allow to send additional information to an activation server.
