Can I select old VM architecture to reduce file size?
zksxmk12
Post by zksxmk12 »
Protected file size is toooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo big.
Re: Can I select old VM architecture to reduce file size?
Open your .vmp file and add VMOptions in the Protection node:
<?xml version="1.0" encoding="UTF-8" ?>
<Document>
    <Protection InputFileName="..." Options="..." VMOptions="XX">
VMOptions |= 1 - vmprotect will use old virtual machine (from 2.X)
VMOptions |= 2 - vmprotect will use only one virtual machine instead of maximum count
So VMOptions="3" will help you to make small files.
abcdefghijklnmopqrst
Post by abcdefghijklnmopqrst »
Admin wrote:Open your .vmp file and add VMOptions in the Protection node:
<Document>
So 3 is old virtual machine+only one virtual machine?
"VMOptions" don't work starting 3.8
