Adding > 4096 RSA key sizes
Ambro
Post by Ambro »
Is it possible in a future release to add in the other RSA key sizes > 4096 to the vmp UI. Considering that up to 16384 bits is supported, it would be convenient to be able to generate these keys directly from within the application.
I'm currently using a convoluted process of generating RSA keys in OpenSSL and manually converting the modulus and exponent to base64, then finally pasting into my .vmp project file. It's inelegant, but it works for now.
Thank you for the consideration.
Re: Adding > 4096 RSA key sizes
Did you try to make 16384 bits keys and generate a serial number? It may take several minutes. I'm not sure that your customers will be happy with such performance :))
Ambro
Post by Ambro »
Admin wrote:Did you try to make 16384 bits keys and generate a serial number? It may take several minutes. I'm not sure that your customers will be happy with such performance :))
It does take quite a while to generate a 16384 bit key, but 8192 is a good compromise :lol:
