VMProtect for ARM64 coming soon
In progress...
- 2.png (108.84 KiB) Viewed 38080 times
- 1.png (75.61 KiB) Viewed 38080 times
Re: VMProtect for ARM64
Great news!
1. What operating systems planned to be supported in the arm64 release? Based on PAC instructions, I see that code above is likely from macOS (M1).
2. Is there a way to join beta-test(for registered users)?
3. And of course, what is the planned release date
Any news about it? Is there any estimation when it will become available?
As far as I know, you are no longer using our product, so I don't understand why you are waiting for the ARM64 support.Any news about it? Is there any estimation when it will become available?
We use different protectors depending on target platform and architecture. An older version of VMProtect is still used in some cases. If ARM64 is supported by VMProtect, we would consider to use VMProtect for ARM64 version of our product.
I see that Code Virtualizer from Oreans can handle ARM64 binaries for different platforms.
My company is interested in if/when VMProtect will work on arm64, as we have a Mac product we need to protect.
Any news for ARM64 protection?
I see that the ARM64 post is not pinned anymore.
Is the ARM64 development still in progress?
Thanks!
Thanks!
Unfortunately we have no any news about ARM64.
Thanks a lot for the reply
Fully completed the code virtualization, support of advanced options (packing, vmtools/debugger detection, memory protection), support of SDK functions (including of licensing and activation systems) for Windows and Linux binaries.
is there any news about the support for m series of macos
The full support of macOS on Apple Silicon chips (ARM64) was added in the internal branch.
