Failed to protect .Net application.
dogesharp
Post by dogesharp »
SDK: .Net Framework 4.7.2
VMP version:1530 (4.7.2)
Error message:Runtime error at CompileToVM: neg
MemProtect,ImportProtect,ResourceProtect,PackOutput were enabled.
Strip debug info was disabled.
Both 4.7.0 and 4.7.1 are worked.
sorry, I cannot provide the source code.
Re: Failed to protect .Net application.
Could you provide us an exanple (original EXE+VMP files) that shows your problem?
dogesharp
Post by dogesharp »
After many many tests,I finally found what code caused this error.
Here is the simple source code.
Form1.rar
(931 Bytes) Downloaded 182 times
Please try the 1537 build.
dogesharp
Post by dogesharp »
Admin wrote:Please try the 1537 build.
Thanks,fix confirmed!
By the way,it seems that app using FodyWeavers.Costura (a .net assemblies packer plugin) cannot enabled Strip Debug Info function.Any idea on this?
the error is :
[Error] Can't resolve assembly: mscorlib, Version=0.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
The problem is here:
