Dear Admin, I will be very glad if you could help me to understand the GenKeyExample.
When I compile it with Delphi I always a wrong result: UNSUPPORTED_NUMBER_OF_BITS = 2
I can not understand this example if I can not make it useful !!!
Why these parameters are all zero (0)?
// !!! this block should be generated by VMProtect License Manager !!! ///
g_Algorithm: Longword = ALGORITHM_RSA;
g_nBits: Longword = 0;
g_vModulus: array [0..0] of Byte = (0);
g_vPrivate: array [0..0] of Byte = (0);
g_vProductCode: array [0..0] of Byte = (0);
Please, help me to understand this Example and Thank you !!!
GenKeyExample returns always UNSUPPORTED_NUMBER_OF_BITS = 2
Re: GenKeyExample returns always UNSUPPORTED_NUMBER_OF_BITS = 2
You have to export your licensing parameters from VMP project to the sources of GenKeyExample:
http://vmpsoftware.com/vmprotect/user-manual#export
