VMProtectBeginUltraLockByKey with Delphi
andthe
Post by andthe »
I set a correct Serial in Delphi and before call the locked procedure I confirmed that the Serial is Ok...
I confirmed also, that (VMProtectGetSerialNumberState() returns = SERIAL_STATE_SUCCESS = (0)
Where is the wrong here ???
My code is the below:
if (VMProtectGetSerialNumberState() = SERIAL_STATE_SUCCESS) then
VMProtectBeginUltraLockByKey('LoginClick');
// This is my procedure that must be locked with serial number
ConnectToServer();
VMProtectEnd;
Thank you !
andthe
Re: VMProtectBeginUltraLockByKey with Delphi
Post by andthe »
Sorry, I forgot to tell you that , even I have a right Serial when I press the button with the above code I sent you I get the following message:
This code requires valid serial number to run.
Program will be terminated.
Could you send us very simple example (original EXE+VMP files) that shows your problem?
andthe
Post by andthe »
This is a link of an example project in Delphi with 'VMProtectBeginUltraLockByKey' (Includes: LockToSerial.exe, LockToSerial.vmp.exe):
https://drive.google.com/drive/folders/ ... share_link
Thank you and I hope to hear from you soon !
andthe
Post by andthe »
Dear Admin,
This is closed !
I found that the problem was in vmp file.
I created a new vmp file and the problem solved !
Thank you very much !
