use Thales Sentinel envelope + AppOnChip + VMprotect
TomBarisano
Post by TomBarisano »
Yes I already read FAQ, it not recommend
but what if have OCD protection fetish and want to use Thales Sentinel Envelope and some appOnChip with VMprotect same time?
Is there way to turn off some settings so that VMprotect can accept this without error?
Jules90
Re: use Thales Sentinel envelope + AppOnChip + VMprotect
Post by Jules90 »
anyway apponchip requires driverless dongles NOT working with SL license and new Cloud license for example.
if you will ONLY provide exclusive dongles to your customers you can use apponchip being most secure protection,
because parts of code from envelope are execute inside virtual machine of Sentinel HL dongles.
anyway you can use that dongle in other ways simply encrypt - decrypt all saved files, encrypt buffer when save export and decrypt while open import
no one can emulate such protection, because project data's always changes.
just read manual and ask Thales send undocumented help sure if pay big fat payment.
We strongly don't recommend to use our product with other packer/protector because you can get incorrect behaviour of the protected application and we will not try to solve it.
What errors do you mean?
