WebClient Ssl/Tls error
levitmic
Post by levitmic »
have a problem with protecting my soft with VMProtect.
url (with redirect)- no secerity, no SSL/TLS (HTML 1.1, http) In Visual Studio I have no Errors (compiled, without protection).
WebClient webClient = new WebClient();
webClient.Headers.Add(HttpRequestHeader.UserAgent, Agent);
content = await webClient.DownloadStringTaskAsync(url);
With this code i have an error: The request was aborted. Could not create SSL/TLS connection
I tried to add (before and after new Weblicent()):
ServicePointManager.Expect100Continue = true;
ServicePointManager.ServerCertificateValidationCallback = delegate { return true; };
ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls | SecurityProtocolType.Tls11| SecurityProtocolType.Tls12 | SecurityProtocolType.Ssl3;
Also tried add only this:
ServicePointManager.SecurityProtocol = SecurityProtocolType.Tls12 (and with Ssl3)
Not worked: Eset antivirus blocking: MSIL/TrojanDownloader.Agent.LNO
Re: WebClient Ssl/Tls error
Are you a registered user of VMProtect?
levitmic
Post by levitmic »
No, I downloaded demo version to test how it's works. Currently I'm on ArmDot.
I need more securely protection.
Could you send us a test example (original EXE+required DLLs +VMP files) that shows your problem?
levitmic
Post by levitmic »
Admin wrote:Could you send us a test example (original EXE+required DLLs +VMP files) that shows your problem?
I can't do it, due to "confidentiality" and url link can't be exposed now.
This code that make a problem...
P.S: POST method to another server with SSL works fine.
