CLI Portable?
Joey
CLI Portable?
Post by Joey »
Hello I am interested in purchasing a professional license, however I need to know if the application (specifically the CLI) can run without installation.
I am running inside a serverless instance, through ci/cd files get hosted on a temporary disk, some of these files require protection. Because of the containerized state I am in, it is unable to install applications. Hopefully the CLI can be ran without installation.
Re: CLI Portable?
Yes, it can work without installation.
Joey
Re: CLI Portable?
Post by Joey »
What would be the correct process? In case of the Demo I've tried to deploy the files after installation, but it gets no response from the VMProtect_Con on the command line.
Re: CLI Portable?
Just copy VMProtect_Con.exe to required computer. That's all.
