The program starts slowly on some computers
When I use the default configuration of 3.8, the output exe starts slowly on some computers, and some even take a few minutes. When I switch to VMProtect 2. X, there is no problem. Attachment is my settings. Is there any way to solve this problem? In addition,What is the specific difference between default and VMProtect 2.X?
- error.png (12.73 KiB) Viewed 6418 times
Re: The program starts slowly on some computers
Please try the 1681 build.When I use the default configuration of 3.8, the output exe starts slowly on some computers, and some even take a few minutes.
This is old VM from 2.X version. We strongly recommend to use the "Default" VM version with Complexity >= 20%. Also you can specify different Complexity value for each function with "Virtualization" or "Ultra" compilation type.In addition,What is the specific difference between default and VMProtect 2.X?
if i can suggest. On entrypoint put only mutation. or at latest virtualization try it few time and see which one speed up code execution of your software. also as the admin suggest try last bulld. which works perfectly!Shzc wrote:When I use the default configuration of 3.8, the output exe starts slowly on some computers, and some even take a few minutes. When I switch to VMProtect 2. X, there is no problem. Attachment is my settings. Is there any way to solve this problem? In addition,What is the specific difference between default and VMProtect 2.X?
Thank you! The new version works well.GHTheBoss wrote:if i can suggest. On entrypoint put only mutation. or at latest virtualization try it few time and see which one speed up code execution of your software. also as the admin suggest try last bulld. which works perfectly!Shzc wrote:When I use the default configuration of 3.8, the output exe starts slowly on some computers, and some even take a few minutes. When I switch to VMProtect 2. X, there is no problem. Attachment is my settings. Is there any way to solve this problem? In addition,What is the specific difference between default and VMProtect 2.X?
I found a new problem. Some computers cannot start the program after using the new version. This error will occur: "File corrupted! This program has been manipulated any maybe it’s infected by a Virus or cracked."
Shzc wrote:I found a new problem. Some computers cannot start the program after using the new version. This error will occur: "File corrupted! This program has been manipulated any maybe it’s infected by a Virus or cracked."
Hello can u let know us, which build, exactly you use ?
It seems someone modifies your application in the memory, so the protected application shows the error.This error will occur: "File corrupted! This program has been manipulated any maybe it’s infected by a Virus or cracked."
Like you recommended. I have tried many options, including VMProtect 2 X, but they all failed. Only the program without VMP can work normally. I'm not sure if this is caused by the new version of Windows system(Windows10 Feature Experience Pack 120.2212.4190.0)GHTheBoss wrote:Shzc wrote:I found a new problem. Some computers cannot start the program after using the new version. This error will occur: "File corrupted! This program has been manipulated any maybe it’s infected by a Virus or cracked."
The feedback person said that it had no problem using the previous version of last November. That is, using previous versions of VMP may avoid this issue, but I haven't tested it yet.Admin wrote:It seems someone modifies your application in the memory, so the protected application shows the error.This error will occur: "File corrupted! This program has been manipulated any maybe it’s infected by a Virus or cracked."
Usually such problem doesn't occur in our software, but using trash antiviruses (like Chinese 360, Microsoft Defender, ESET NOD32, Avira, etc.). As I remember some software from Intel also modifies applications in the memory. Ask your customers to check your software with the clean Windows without any third-party software.
Thank you. We will check other software later.Admin wrote:Usually such problem doesn't occur in our software, but using trash antiviruses (like Chinese 360, Microsoft Defender, ESET NOD32, Avira, etc.). As I remember some software from Intel also modifies applications in the memory. Ask your customers to check your software with the clean Windows without any third-party software.
