New "Complexity" Value
LZBNBJc5D6Qg3i
Post by LZBNBJc5D6Qg3i »
Hey Im wondering about the new "Complexity" option introduced with VMProtect 3.8.
What was the default internal value before the update made it configurable? Because if i set it to 100% it increases my file size by ~30MB
What exactly does a "complex" function inside of the VM mean and what does it protect you from?
Thanks
Re: New "Complexity" Value
The "Complexity" sets the probability of creating complex handlers inside the virtual machine, which can consist of many simple operations. "Complexity = None (0%)" doesn't create complex handlers and it works like previous versions. Complexity breaks all existing tools for analyzing/decompiling of virtualized code.
LZBNBJc5D6Qg3i
Admin wrote:The "Complexity" sets the probability of creating complex handlers inside the virtual machine, which can consist of many simple operations. "Complexity = None (0%)" doesn't create complex handlers and it works like previous versions.
Thank you for the explanation!
Is it similar to inserting junk instructions like the Mutation?
Does Complex help against Reverse Engineering and does it impact performance?
EDIT: If i set it to 50%, will that still add complexity to ALL of the virtual machines?
LZBNBJc5D6Qg3i
Admin wrote:Complexity breaks all existing tools for analyzing/decompiling of virtualized code.
So do you recommend setting it to 100%?
Code02
Post by Code02 »
I am also interested to know more about this option.
What is the default complexity value?
Which is the recommended one?
Why settings complexity at 20% produces smaller executables, then when setting complexity to none?
Options - Virtual Machine - Complexity has no the default value.
Any value more than 0%
Usually Complexity increases the size of a protected file.
abcdefghijklnmopqrst
Post by abcdefghijklnmopqrst »
You might be interested.
viewtopic.php?f=2&t=30297
