Virtual Machine Instances
Code02
Post by Code02 »
What does the instances option do?
How does the "instances" option affect in terms of protection, executable size and code speed?
What is the default value?
Any recommendations?
Thanks.
Re: Virtual Machine Instances
Virtual Machine - Instances - this options allows to specify the number of the virtual machine copies (the default value is 10). Each virtual machine have unique set of properties (different registers positions, different bytecode direction, different handlers of commands, etc.) that makes harder the analysis and hacking of virtualized code.
