VMProtect increases program startup time.
yuezhicheng
Post by yuezhicheng »
When I use VMProtect software to protect my *.exe file, which is 137 MB, it increases the startup time of the program. Before I protect it, it only takes less than 1 second. Instead, it takes more than 10 seconds. How can I solve this problem? My profile list as follows:
- Memory Protection: Yes,
- Import Protection: Yes,
- Resource Proction: Yes,
- Debugger: User-mode + Kernel-mode,
and other options are No.
Re: VMProtect increases program startup time.
Are you a registered user of VMProtect?
yuezhicheng
Admin wrote:Are you a registered user of VMProtect?
Yes. My company is registered, but I do not have permission to use my company's account.
In this case we can't help you with your problem.
