How to remove Imports from KERNEL32.dll
fuzzing
Post by fuzzing »
Is there a chance to remove imports of KERNEL32.dll when using all protection options?:
GetSystemTimeAsFileTime
HeapAlloc
HeapFree
ExitProcess
LoadLibraryA
GetModuleHandleA
GetProcAddress
Regards!
Re: How to remove Imports from KERNEL32.dll
Why do you need it?
fuzzing
Post by fuzzing »
Admin wrote:Why do you need it?
As i posted before, with "Detect It Easy" tool a cracker can identify VMP:
viewtopic.php?f=2&t=30016&p=36570#p36570
kernel32.dll
PE.getImportFunctionName(x,x)=="GetSystemTimeAsFileTime"
And all combinations of the Import ...
Fixed in the 1790 build.
