KINDLY PLEASE RESOLVE - IT EXTRACT ALL MY DLL FILES
surprise2101
Post by surprise2101 »
RESPECTED SIR/MADAM,
I AM PROTECTED MY EXE WITH DEMO VERSION OF 3.7.3 BUILD 1628
I OPEN EXE AND DLL FILES ,ADD VIRTUALISATION AND PROTECT IT
THAN I OPEN MY PACKED EXE, NOW I CHECKED IT FROM EXTREME DUMPER..
IT WILL EXTRACT ALL OF MY IMPORTANT DLL FILES & ALL CODE IS SHOWN
REGARDS
Re: KINDLY PLEASE RESOLVE - IT EXTRACT ALL MY DLL FILES
You have to use the code virtualization for all critical methods in your EXE/DLL files.
surprise2101
Re: KINDLY PLEASE RESOLVE - IT EXTRACT ALL MY DLL FILES-NOT SOLVED
RESPECTED SIR/MADAM,,.
I AM NEW IN VMP PROTECTION AND I AM USING UR TRIAL VERSION...
I HAVE ONE SIMPLE EXE AND 10 DLL FILES ,I WANT TO MERGE IN SINGLE EXE...
FIRST I OPEN EXE AND AFTER THAT I ADD DDL ON ASSEMBLY...
I SELECT CODE VIRTUALISATION BUT SHOW EXE CODE VIRTUALISATION....
HOW TO SELECT BOTH CODE VIRTUALISATION OF EXE AND DLL FILES BOTH...
I WANT SINGLE EXE....
KINDLY PLEASE RESOLVE THIS ...I AM VERY THANKFUL TO U ....
REGARDS
