can not compile with version 2.x
cnlidah
Post by cnlidah »
when i compile 32 bits exe with option <VMVersion="1"> by VMProtect V3.8.5. it report "Runtime error at CompileToNative".
64 bits exe is ok.
Re: can not compile with version 2.x
Could you send as a test example (original binary + VMP file) that shows this problem?
cnlidah
Post by cnlidah »
Admin wrote: Thu Nov 09, 2023 9:12 am Could you send as a test example (original binary + VMP file) that shows this problem?
the vmp and exe files are in "Release" subdirectory. this is a VS2017 project. see attached zip file.
MFCApplication1.zip
(2.27 MiB) Downloaded 238 times
Fixed in the 1885 build.
cnlidah
Post by cnlidah »
Looking forward to the new version.
