error while protecting nt8 dll
banktrader01
Post by banktrader01 »
hi want to help me what is that log I selected all functions but I got this error in dll protection function and process
Re: error while protecting nt8 dll
Are you a registered user of VMProtect?
banktrader01
i am checking the demo version to see if I can use protect my dll filed or not its nt8 add on
what should I do ?
that error fixed now I got this error
This error means that the assembly wasn't found on your computer.
banktrader01
which assembly do you mean? the main assembly or direct assembly of windows?
is there any tutorial on how can protect only dll files or any customer use your software for protecting nt8 add on ?
I mean the assembly that you see in the error message (SharpDX.Direct2D1).
