Protected file produced different result.
weloveayaka
Post by weloveayaka »
Minimal code:
target .net framework 4.8.1
In fact, this is the minimal implementation code for a part of a more complex project.
Due to the type being changed to System.Object, code encountered issues in build 1879.
Actually, I heavily rely on reflection and proxies.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Runtime.Remoting.Proxies;
using System.Runtime.Remoting.Messaging;
namespace test1
    internal class Program
        static void Main(string[] args)
            var service = new Service();
            var proxy = new Proxy(service);
            var interfaceProxy = (IInterface)proxy.GetTransparentProxy();
            interfaceProxy.DoSomething();
            Console.Read();
        public class Proxy : RealProxy
            private IInterface _target;
            public Proxy(IInterface target) : base(typeof(IInterface))
                _target = target;
            public override IMessage Invoke(IMessage msg)
                if (msg is IMethodCallMessage methodCall)
                    Console.WriteLine("Proxy is intercepting the method call.");
                    Console.WriteLine(methodCall.TypeName.ToString());
                    var result = methodCall.MethodBase.Invoke(_target, methodCall.InArgs);
                    Console.WriteLine("Proxy has called the service class method.");
                    return new ReturnMessage(result, null, 0, methodCall.LogicalCallContext, methodCall);
                return null;
    public class Service : MarshalByRefObject, IInterface
        public void DoSomething()
            Console.WriteLine("Service is doing something.");
    public interface IInterface
        void DoSomething();
config:
<?xml version="1.0" encoding="UTF-8" ?>
<Document Version="2">
    <Protection InputFileName="test1.exe" Options="70400" VMCodeSectionName=".???" VMComplexity="20">
        <Messages />
        <Folders />
        <Procedures>
            <Procedure MapAddress="test1.Program::Main(string[])" Options="0" CompilationType="2" />
            <Procedure MapAddress="test1.Program::.ctor()" Options="0" CompilationType="2" />
            <Procedure MapAddress="test1.Service::DoSomething()" Options="0" CompilationType="2" />
            <Procedure MapAddress="test1.Service::.ctor()" Options="0" CompilationType="2" />
            <Procedure MapAddress="test1.Program/Proxy::.ctor(class test1.IInterface)" Options="0" CompilationType="2" />
            <Procedure MapAddress="test1.Program/Proxy::Invoke(class System.Runtime.Remoting.Messaging.IMessage)" Options="0" CompilationType="2" />
        </Procedures>
        <Objects />
    </Protection>
    <Script />
</Document>
Original result:
test1.IInterface, test1, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
Protected Result:
System.Object, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
weloveayaka
Re: Protected file produced different result.
In reality, we dynamically create objects in the Invoke method based on the content of the IMethodCallMessage, rather than having a _target variable as shown in the example. Therefore, when the file is protected, an additional Invoke is triggered to call System.Object's GetType. This causes our program to run incorrectly, failing to create the correct object. We end up not knowing who to proxy for, as we can't find the relevant IInterface at that time
The virtual machine calls Object.GetType while emulation of castclass instruction in "void test1.Program::Main(string[])":
.maxstack 8
newobj 06000004 → instance void test1.Service::.ctor()
newobj 06000006 → instance void test1.Program/Proxy::.ctor(class test1.IInterface)
callvirt 0A000011 → instance object [mscorlib]System.Runtime.Remoting.Proxies.RealProxy::GetTransparentProxy()
castclass 02000004 → test1.IInterface
callvirt 06000005 → instance void test1.IInterface::DoSomething()
call 0A000012 → int32 [mscorlib]System.Console::Read()
pop
ret
Anyway, I don't see any bugs here.
weloveayaka
Hello Admin, this is a preliminary example. In terms of the direct outcome of the program, it results in inconsistent execution.
In practical processes, we utilize such a method for IoC + Service Locator.
As a result, since GetType runs before the specific class, we are unable to locate the concrete service.
public override System.Runtime.Remoting.Messaging.IMessage Invoke(System.Runtime.Remoting.Messaging.IMessage message)
            System.Runtime.Remoting.Messaging.IMethodCallMessage methodMessage = new System.Runtime.Remoting.Messaging.MethodCallMessageWrapper((System.Runtime.Remoting.Messaging.IMethodCallMessage)message);
            System.Reflection.MethodBase method = methodMessage.MethodBase;
            if (interfaceType == null) interfaceType = method.DeclaringType;
            // becuase addtional System.Object.GetType() called here. it can't find service and unable to initialize service class
            // if it's not System.Object.GetType() calling, it should be an Iinterface type and then we can get the actual service class initialized then invoke something..
            if (target == null) target = getObject(interfaceType);
             // some code to invoke method...
Can we avoid the initial System.Object.GetType()?
If it's unavoidable, as a workaround, could you tell us what to return?
Whether we return typeof(object), typeof(this), or null, it leads to a NullReferenceException.
I understand that we should return an IInterface Type at this point, but since System.Object.GetType is called first, we are unable to determine what the IInterface is.
give me a liitle time, I'll give you another example later
You can use castclass without virtualization with the following code:
        static T CastTo<T>(object obj) where T : class
            return obj as T;
            var interfaceProxy = CastTo<IInterface>(proxy.GetTransparentProxy());
            Console.Read();
weloveayaka
Please try this one:
using System;
using System.Linq;
using System.Text;
using System.Reflection;
using System.Runtime.Remoting;
namespace test1
            ServiceFactory.RegisterService(typeof(IInterface), typeof(Service));
            IInterface service = ServiceFactory.GetService() as IInterface;
            service.DoSomething();
            Console.Read();
        public class UniversalServiceProxy : RealProxy, IRemotingTypeInfo
            public string TypeName { get => throw new NotImplementedException(); set => throw new NotImplementedException(); }
            public UniversalServiceProxy() : base(typeof(MarshalByRefObject))
                var methodCall = msg as IMethodCallMessage;
                var methodInfo = methodCall.MethodBase as MethodInfo;
                Type serviceInterfaceType = methodInfo.DeclaringType;
                if (!ServiceFactory.IsServiceRegistered(serviceInterfaceType))
                    throw new InvalidOperationException($"No service registered for type {serviceInterfaceType.Name}");
                Type implementationType = ServiceFactory.GetImplementationType(serviceInterfaceType);
                object serviceInstance = Activator.CreateInstance(implementationType);
                try
                    Console.WriteLine($"Invoking method {methodInfo.Name} on {implementationType.Name}");
                    var result = methodInfo.Invoke(serviceInstance, methodCall.Args);
                    Console.WriteLine($"Method {methodInfo.Name} on {implementationType.Name} invoked successfully");
                catch (Exception e)
                    Console.WriteLine($"Exception occurred during invocation: {e.Message}");
                    return new ReturnMessage(e, methodCall);
            public bool CanCastTo(Type fromType, object o)
                return ServiceFactory.IsServiceRegistered(fromType);
        public static class ServiceFactory
            private static readonly Dictionary<Type, Type> _services = new Dictionary<Type, Type>();
            public static void RegisterService(Type interfaceType, Type implementationType)
                _services[interfaceType] = implementationType;
            public static object GetService()
                var proxy = new UniversalServiceProxy();
                return proxy.GetTransparentProxy();
            public static bool IsServiceRegistered(Type interfaceType)
                return _services.ContainsKey(interfaceType);
            public static Type GetImplementationType(Type interfaceType)
                return _services[interfaceType];
        void DoSomething();
Before protect:
Invoking method DoSomething on Service
Method DoSomething on Service invoked successfully
After protect:
System.InvalidOperationException: No service registered for type Object
This example is more closer to our actual situation.
To prevent piracy, we have hundreds of functions that need protection, and if possible, we would prefer to avoid modifying existing code as much as we can. We hope you can provide some suggestions. Thank you!
( Only Main function to be protected, use Ultra )
weloveayaka
Admin wrote: Mon Nov 27, 2023 9:10 am You can use castclass without virtualization with the following code:
            return obj as T;
            Console.Read();
I tried this one, modified to this: (based on above example)
            IInterface service = CastTo<IInterface>(ServiceFactory.GetService());
            Console.Read();
            return obj as T;
It did work, but since there is already a lot of existing code, (it's a very large product.) is there a solution that does not involve modifying the existing code?
You still don't understand what your code does (virtualized "isinst" works like "castclass" and it calls Object.GetType too).
            return obj as T;
            Console.Read();
weloveayaka
It seems we have to modify current code,
Thank you for your help!
weloveayaka
Sorry to bother you again
It's about exception this time:
using System;
using System.Linq;
using System.Text;
namespace @catch
            try
                A();
            catch (CustomException ex) {
                Console.WriteLine("Catch Custom Exception");
            catch (Exception ex)
                Console.WriteLine("Catch Exception");
            Console.Read();
        static void A()
            throw new CustomException();
    class CustomExceptionBase : Exception {
    class CustomException : CustomExceptionBase
Before virtualization:
it outputs "Catch Custom Exception"
After virtualization
it outputs "Catch Exception"
build 1754 and 1879
The virtual machine calls A() via MethodInfo.Invoke that doesn't support BindingFlags.DoNotWrapExceptions for .NET Framework. So the class an exception in the "catch" block is wrong ("TargetInvocationException" instead of "CustomException"). The virtualized "A()" will throw correct exception.
weloveayaka
I think this is very challenging, as it means more functions require virtualization. For instance, if I need to call a service and catch its various exceptions, it's not just about virtualizing this function, but also virtualizing the service and its internal call chain.
It's not only A(), but also A->B->C->D->.....
This also means that if we miss adding any function, it could lead to changes in the behavior of the application.
I earnestly request you to make the necessary modifications.
In our code, a function may call different assembly, and the call chain may be very very long.
We indeed need to virtualize the functions, so we can't remove virtualization.
However, it's nearly impossible for us to fully apply virtualization to the entire call chain.
weloveayaka
Also, some Exceptions are throw by System, which is impossible to virtualization
 try
                var a = System.IO.File.ReadAllText(@"c:\notexist.txt");
            catch (System.IO.FileNotFoundException ex) {
                Console.WriteLine("Catch FileNotFoundException");
            Console.Read();
this also enter wrong catch block
Could you please find another way to avoid this? Alternative way to replace DoNotWrapExceptions?
weloveayaka wrote: Mon Nov 27, 2023 10:54 pm this also enter wrong catch block
Please try the 1911 build.
weloveayaka
Thank you to fix the problem in 1911build. Could you please also send the fixed build to ...
Which is also the registered user email, it's my employer.
Thank you very very very much!!!!
