very strange TypeInitializationException
weloveayaka
Post by weloveayaka »
We used a static property in an unvirtualized class from another DLL in a Windows Application.
The getter of this static property returns the result of a virtualized static function that returns a constant.
this code below is only for code structure
Program
void Main(string[] args){
 	AppDomain.CurrentDomain.UnhandledException += Program.HandlerUnCatchException;
 	Program.XXX = classB.SomeEnum;    <---- Exception
LibraryA:
public sealed classB
    private static classB CONSTANTS = new classB();
    	 private classB()
        	// xxx
        public classB(int x)
        static string prop = string.Empty;
        [Obfuscation(Feature = "virtualization", Exclude = false)]    <------ this getter is not virtualized, but it's not a main problem.
        public static string SomeEnum
            get
                if (string.IsNullOrEmpty(prop))  <---   TypeInitializationException here
                   // get prop from another place.
                return prop;
            set
                prop = value;
LibraryB
 public class LibraryB
        public static SomeEnum GetEnum()
            return SomeEnum.Something;
On some computers, DLLs would throw a TypeInitializationException.
the stack is
System.NullReferenceException                      <------- LibraryB
    7BB4AD2E.E62B8B3C()
    7BB4AD2E.BD0CC42C(System.Object[], Int32)
    <Module>..cctor()
Exception: System.TypeInitializationException       <---------- LibraryA
    LibraryA.ClassB..ctor()
    LibraryA.ClassB..cctor()
However, if we recompiled the DLL with the same codebase and VMP configuration and replaced it, it would not throw the exception anymore. (recompile LibraryB)
Even if I added a 16 character parameter (/ffffffffffffffff, which is meaningless) , it would not report the exception either.
What's even more bizarre is that if I start this program in a debugger, then it won't fail either.
But on some other computers, with the same files (the original file, not the rebuilt one) , compile configuration and run parameters, it would not report any exception.
This sounds like it could be a multi-threading, GC or memory issue.
The VMP configuration is:
<?xml version="1.0" encoding="UTF-8" ?>
<Document Version="2">
    <Protection InputFileName="LibraryB.dll" Options="69888" VMCodeSectionName=".???" VMComplexity="20">
        <Messages />
        <Folders />
        <Procedures />
        <Objects />
    </Protection>
    <Script />
</Document>
we use ObfuscationAttribute to assign virtualized method. so vmp configuration is empty.
Because we are unable to recompile a problematic version, we are unable to provide a minimized code sample that reproduces the issue.
Since this is part of a large software system, it is also very difficult for us to provide a runnable program.
Also, I tried disable DEP on OS, not working. very strange and unpredictable
Re: very strange TypeInitializationException
Could you send us a very simple example (original binaries + VMP file) that shows your problem?
